BEA Database
AASA
BEA Database
Postby AASA » Sun Oct 18, 2020 10:56 am
I am having trouble using the BEA database. I entered my code from the BEA then proceeded to select BEA data. When I select "filter" nothing happens.
See attached file.
BEA Data Request Attempt.docx
(31.64 KiB) Downloaded 1091 times
EViews Katerina
Re: BEA Database
Postby EViews Katerina » Mon Oct 19, 2020 9:25 am
After you click Browse on database window (before you click Filter) do you see a list of datasets like the attached screenshot?
AASA
Re: BEA Database
Postby AASA » Mon Oct 19, 2020 9:17 pm
No.
See attached file for what I see.
BEA Data Request Attempt_1.docx
(24.57 KiB) Downloaded 1185 times
EViews Katerina
Re: BEA Database
Postby EViews Katerina » Tue Oct 20, 2020 9:25 am
1. Are you behind a proxy server? In that case make sure that EViews is configured correctly.
2. Please try this on a browser window :
https://apps.bea.gov/api/data/?UserID=[b]BEAKEY[/b]&method=GETDATASETLIST&resultformat=json
Make sure to replace the BEAKEY with your Key. Do you should see a json response with the BEA datasets like :
{"BEAAPI":{"Request":{"RequestParam":[{"ParameterName":"METHOD","ParameterValue":"GETDATASETLIST"},{"ParameterName":"RESULTFORMAT","ParameterValue":"JSON"}]},"Results":{"Dataset":[{"DatasetName":"NIPA","DatasetDescription":"Standard NIPA tables"},{"DatasetName":"NIUnderlyingDetail","DatasetDescription":"Standard NI underlying detail tables"},{"DatasetName":"MNE","DatasetDescription":"Multinational Enterprises"},{"DatasetName":"FixedAssets","DatasetDescription":"Standard Fixed Assets tables"},..}
AASA
Re: BEA Database
Postby AASA » Tue Oct 20, 2020 10:32 am
1. I don't know what a proxy server is.
2. What does the app code do? Does it change my Windows settings?
Re: BEA Database
Postby EViews Gareth » Tue Oct 20, 2020 10:40 am
2. No, it loads a webpage.
Also, what version/date is your copy of EViews? (Help->About EViews).
AASA
Re: BEA Database
Postby AASA » Tue Oct 20, 2020 11:57 am
1. EViews 11
2. October 5, 2020.
AASA
Re: BEA Database
Postby AASA » Tue Oct 20, 2020 4:34 pm
The attached file shows what I get when I key the code supplied for the BEAPPI, using my registration.
When I selected the "preview" tab and the the "submit" tab, the attached file posted and I no longer see the attached file on the previous unedited response.
BEAAPI request.png (95.08 KiB) Viewed 27599 times
EViews Katerina
Re: BEA Database
Postby EViews Katerina » Tue Oct 20, 2020 4:56 pm
It seems that you have an invalid UseriId.
To check the API Key open the BEA database from EViews. Select Views->Preferences...
Check the BEA API Key if it is correct. You can also request a new key by clicking the link (https://apps.bea.gov/API/signup/index.cfm) on the preferences window.
AASA
Re: BEA Database
Postby AASA » Tue Oct 20, 2020 7:25 pm
I got a new Userid and hand typed it into the EViews box and it now works. I had copied and pasted the previous Userid.
I now see the screen similar to what you posted. I will now just need to "play" with the filter and data screens to see what I can find.
