GJR-GARCH(1,1) & TGARCH(1,1)
ecofin
Postby ecofin » Mon Feb 24, 2014 4:57 am
hi everybody, I have seen thant there is diference between GJR-GARCH(1,1) and TGARCH(1,1) when I estimate the two models with Mathlab, my question is: EViews estimate GJR-GARCH(1,1) or TGARCH(1,1)?.
Reference: Financial modeling Under Non-Gaussian Distribution, Eric Jondeau, Ser-Huang Poon and Michael Rockinger, Springer 2007, pp 95 and pp 100.
pp_100.pdf
(93.66 KiB) Downloaded 605 times
pp_95.pdf
(172.5 KiB) Downloaded 514 times
trubador
Did you use forum search?
Re: GJR-GARCH(1,1) & TGARCH(1,1)
Postby trubador » Mon Feb 24, 2014 12:13 pm
ecofin
Postby ecofin » Thu Feb 27, 2014 11:43 am
thanks for your response, So there is not a way to estimate original TGARCH(1,1) in EViews 8. :cry:
trubador
Postby trubador » Thu Feb 27, 2014 2:07 pm
No, not built-in. But you can always build such customized models via LogL object.
ecofin
Postby ecofin » Mon Mar 03, 2014 12:57 pm
but i don't know where to start, I'm not an expert on Eviews programming, Can you help me for the code to customized TGARCH(1,1), and thanks for your help and for your reply.
trubador
Postby trubador » Mon Mar 03, 2014 3:31 pm
You can start by examining the customized GARCH examples written via LogL object: "C:\Program Files\EViews 8\Example Files\Sample Programs\logl". And you can always search forum for similar examples...
ecofin
Postby ecofin » Tue Mar 04, 2014 12:40 pm
just i can estimate the original TARCH model with PARCH model when i fix the power=1 but i loss the threshod order :? normally it should leave this option :!:
