hi everybody, I have seen thant there is diference between GJR-GARCH(1,1) and TGARCH(1,1) when I estimate the two models with Mathlab, my question is: EViews estimate GJR-GARCH(1,1) or TGARCH(1,1)?.
Reference: Financial modeling Under Non-Gaussian Distribution, Eric Jondeau, Ser-Huang Poon and Michael Rockinger, Springer 2007, pp 95 and pp 100.
GJR-GARCH(1,1) & TGARCH(1,1)
- pp_100.pdf
- (93.66 KiB) Downloaded 606 times
- pp_95.pdf
- (172.5 KiB) Downloaded 515 times
Re: GJR-GARCH(1,1) & TGARCH(1,1)
Search is a useful tool: http://forums.eviews.com/viewtopic.php? ... =gjr#p9147
thanks for your response, So there is not a way to estimate original TGARCH(1,1) in EViews 8.
No, not built-in. But you can always build such customized models via LogL object.
but i don't know where to start, I'm not an expert on Eviews programming, Can you help me for the code to customized TGARCH(1,1), and thanks for your help and for your reply.
You can start by examining the customized GARCH examples written via LogL object: "C:\Program Files\EViews 8\Example Files\Sample Programs\logl". And you can always search forum for similar examples...
just i can estimate the original TARCH model with PARCH model when i fix the power=1 but i loss the threshod order :? normally it should leave this option
