Principal Components Bug?
rmoralesaramburu
Postby rmoralesaramburu » Thu Dec 05, 2013 1:19 pm
Hello, I have a problem with principal components. Eviews shutdown completely. But the strange thing is that principal components works on other workfiles in my Eviews. There is just one particular workfile. I tried creating another workfile and still doesn-t work. Could it be the data? here is the error that I am having. I am attaching all my files . Thanks!
Firma con problemas:
Nombre del evento de problema: BEX
Nombre de la aplicación: EViews8.exe
Versión de la aplicación: 8.0.0.0
Marca de tiempo de la aplicación: 521d3026
Nombre del módulo con errores: StackHash_8993
Versión del módulo con errores: 0.0.0.0
Marca de tiempo del módulo con errores: 00000000
Desplazamiento de excepción: 00000001
Código de excepción: c0000005
Datos de excepción: 00000008
Versión del sistema operativo: 6.1.7601.2.1.0.256.4
Id. de configuración regional: 1033
Información adicional 1: 8993
Información adicional 2: 8993bc87481708d1b8616b33cf9eb67e
Información adicional 3: d3de
Información adicional 4: d3de56682088c7a717f0966186873a9c
iarp model.prg
(662 Bytes) Downloaded 409 times
bd_iarp.wf1
(158.34 KiB) Downloaded 372 times
BD_IARP.xlsx
(161.05 KiB) Downloaded 482 times
Re: Principal Components Bug?
Postby EViews Glenn » Thu Dec 05, 2013 1:34 pm
Two quick questions before I dive into this one. (1) What is the build-date on your copy of EViews? (2) Are you running on a machine with a single core or using virtualization software?
[edit] a quick check doesn't reveal any problems in currently shipping EViews.
rmoralesaramburu
Postby rmoralesaramburu » Thu Dec 05, 2013 2:02 pm
Aug 27, 2013
Intel(R) Core(TM) i5-2400 CPU @3.10GHz 3.10 GHz
Thanks!
Postby EViews Gareth » Thu Dec 05, 2013 2:12 pm
Could you update to the latest version?
Once you've done that, could you type "supportinfo" at the command line, then copy and paste the results back here.
