Hello, I have a problem with principal components. Eviews shutdown completely. But the strange thing is that principal components works on other workfiles in my Eviews. There is just one particular workfile. I tried creating another workfile and still doesn-t work. Could it be the data? here is the error that I am having. I am attaching all my files . Thanks!
Firma con problemas:
Nombre del evento de problema: BEX
Nombre de la aplicación: EViews8.exe
Versión de la aplicación: 8.0.0.0
Marca de tiempo de la aplicación: 521d3026
Nombre del módulo con errores: StackHash_8993
Versión del módulo con errores: 0.0.0.0
Marca de tiempo del módulo con errores: 00000000
Desplazamiento de excepción: 00000001
Código de excepción: c0000005
Datos de excepción: 00000008
Versión del sistema operativo: 6.1.7601.2.1.0.256.4
Id. de configuración regional: 1033
Información adicional 1: 8993
Información adicional 2: 8993bc87481708d1b8616b33cf9eb67e
Información adicional 3: d3de
Información adicional 4: d3de56682088c7a717f0966186873a9c
Principal Components Bug?
rmoralesaramburu
- iarp model.prg
- (662 Bytes) Downloaded 410 times
- bd_iarp.wf1
- (158.34 KiB) Downloaded 372 times
- BD_IARP.xlsx
- (161.05 KiB) Downloaded 482 times
Re: Principal Components Bug?
Two quick questions before I dive into this one. (1) What is the build-date on your copy of EViews? (2) Are you running on a machine with a single core or using virtualization software?
[edit] a quick check doesn't reveal any problems in currently shipping EViews.
rmoralesaramburu
Aug 27, 2013
Intel(R) Core(TM) i5-2400 CPU @3.10GHz 3.10 GHz
Thanks!
Thanks!
Could you update to the latest version?
Once you've done that, could you type "supportinfo" at the command line, then copy and paste the results back here.
