the data is too much to be operated??
fdmyang
Postby fdmyang » Tue Jun 26, 2012 1:41 am
I'm facing a big problem and I'm really confused by this:
I put around 151,000 data and system told me that the test could not be operated because there are so many data, is this really?? If yes, so how many data it could be??
Thanks!
Postby startz » Tue Jun 26, 2012 7:54 am
You need to be explicit about what you did and what version you're using.
fdmyang
Re: the data is too much to be operated??
Postby fdmyang » Wed Jun 27, 2012 8:57 pm
Ok, thanks for your reply firstly.
I'm using EViews6. I wanna make Unit root test, cointegration test, Husman test, and OLS test. But only the Unit root test could be processed and I have been told that too much data to process while I was tring to run others....How can I do?
fdmyang
Postby fdmyang » Wed Jun 27, 2012 9:05 pm
it said:"Matrix size error: too many parameters for default coefficient vector ". You also plz read attachment I posted here. Thanks.
Postby startz » Wed Jun 27, 2012 10:12 pm
What command lead to the error that you show?
fdmyang
Postby fdmyang » Fri Jun 29, 2012 2:33 am
pool/"Cointegration Test". Is it possible i send the workfile to you by email so that you can check the detail??
fdmyang
Postby fdmyang » Fri Jun 29, 2012 2:37 am
Meanwhile, my data is "unbalance panel data", but there are only three options for selecting in workfile creation which are "dataed- regular frequency", "Unstructed/undated", and"balanced panel data", so which one I should to select?? thanks!
Postby startz » Fri Jun 29, 2012 5:58 am
Be sure your copy of EViews is uptodate. Past that you may need help from the EViews staff.
fdmyang
Postby fdmyang » Sat Jun 30, 2012 8:28 am
sure...i 'll install eviews 7 for a testing...but still be confused by the problem:
Postby EViews Gareth » Sat Jun 30, 2012 1:23 pm
You cannot create an unbalanced panel. You can only open one.
fdmyang
Postby fdmyang » Sun Jul 01, 2012 8:28 pm
Thanks Gareth, so which one i should select among the three while I create workfile?? dated-frequency??
