I'm facing a big problem and I'm really confused by this:
I put around 151,000 data and system told me that the test could not be operated because there are so many data, is this really?? If yes, so how many data it could be??
Thanks!
the data is too much to be operated??
You need to be explicit about what you did and what version you're using.
Re: the data is too much to be operated??
Ok, thanks for your reply firstly.
I'm using EViews6. I wanna make Unit root test, cointegration test, Husman test, and OLS test. But only the Unit root test could be processed and I have been told that too much data to process while I was tring to run others....How can I do?
it said:"Matrix size error: too many parameters for default coefficient vector ". You also plz read attachment I posted here. Thanks.
- 未命名.jpg (9.49 KiB) Viewed 7065 times
What command lead to the error that you show?
pool/"Cointegration Test". Is it possible i send the workfile to you by email so that you can check the detail??
Meanwhile, my data is "unbalance panel data", but there are only three options for selecting in workfile creation which are "dataed- regular frequency", "Unstructed/undated", and"balanced panel data", so which one I should to select?? thanks!
Be sure your copy of EViews is uptodate. Past that you may need help from the EViews staff.
sure...i 'll install eviews 7 for a testing...but still be confused by the problem:
You cannot create an unbalanced panel. You can only open one.
Thanks Gareth, so which one i should select among the three while I create workfile?? dated-frequency??
