arma model
elhamfa
arma model
Postby elhamfa » Mon May 30, 2011 1:27 am
hi.
I came across a problem and I just want to khow that how can I use "correlogram" in eviews to choose a best AR , MA or ARMA model and their best LAGs?
trubador
Did you use forum search?
Re: arma model
Postby trubador » Mon May 30, 2011 4:33 am
Just in the same way as you use ACF and PACF statistics/plots...
stasibab
Re: arma model
Postby stasibab » Tue May 31, 2011 5:15 am
I am trying to use arma model to make an out-of-sample forecast. To be exact I want to specify the best arma model!
I have in-sample 1781 observations and out-of-sample 514 (total 2295)
can you help me on how to do it in EViews?
thank you
arma model.xlsx
(50.01 KiB) Downloaded 395 times
stasibab
Re: arma model
Postby stasibab » Wed Jun 01, 2011 11:59 am
I would like to ask if about the structure of the arma model
using least squares and 'sample' my dependent variable the structure for estimating different arma models
sample c ar(1) ma(1) ar(3) ma(3) : is this a correct structure?
sample c ar(1) ar(3) ma(1) ma(3) : is this the same as the above?
sample c ar(3) ma(3) ar(1) ma(1) : is this correct or have the ar to be in increasing order?
Thank you
Re: arma model
Postby startz » Wed Jun 01, 2011 12:18 pm
The order doesn't matter. But it's unusual to have MA(3) or AR(3) without having MA(2) and AR(2).
stasibab
Re: arma model
Postby stasibab » Wed Jun 01, 2011 12:23 pm
So what do you mean? you have to always have in order like 1 2 3...
Re: arma model
Postby startz » Wed Jun 01, 2011 12:31 pm
You don't have to have them in order, but you probably should include all the intermediate orders.
stasibab
Re: arma model
Postby stasibab » Wed Jun 01, 2011 12:54 pm
Thanx a lot!!
stasibab
Re: arma model
Postby stasibab » Wed Jun 01, 2011 1:08 pm
Thanx a lot!!
Sorry to bother you again but if the structure does not matter how come that when I run
sample c AR(5) AR(4) AR(9) AR(1) MA(5) MA(4) MA(9) MA(1)
AND
sample c AR(1) AR(4) AR(5) AR(9) MA(1) MA(4) MA(5) MA(9)
gives me a different results and makes the coefficients not significant?
stasibab
Re: arma model
Postby stasibab » Wed Jun 01, 2011 1:29 pm
AND
Significant i mean the probabilities of the coefficients to be under 0,05. This must be that way in order to have a good forecast.
Re: arma model
Postby EViews Glenn » Wed Jun 01, 2011 1:44 pm
Hard to say without seeing the workfile.
stasibab
Re: arma model
Postby stasibab » Wed Jun 01, 2011 1:56 pm
thank you
Sorry I had it uploaded before!
I use the 1781 observations for estimation and 2295 for the forecast
stasibab
Re: arma model
Postby stasibab » Wed Jun 01, 2011 1:57 pm
This is it
arma model.xlsx
(50.01 KiB) Downloaded 404 times
Re: arma model
Postby startz » Wed Jun 01, 2011 1:59 pm
AND
You might want to post a picture of your output. You should be getting the same results.
stasibab
Re: arma model
Postby stasibab » Wed Jun 01, 2011 2:16 pm
Ok now I am sending u the two tries.
