arma model
arma model
hi.
I came across a problem and I just want to khow that how can I use "correlogram" in eviews to choose a best AR , MA or ARMA model and their best LAGs?
Re: arma model
Just in the same way as you use ACF and PACF statistics/plots...
Re: arma model
I am trying to use arma model to make an out-of-sample forecast. To be exact I want to specify the best arma model!
I have in-sample 1781 observations and out-of-sample 514 (total 2295)
can you help me on how to do it in EViews?
thank you
thank you
- arma model.xlsx
- (50.01 KiB) Downloaded 394 times
Re: arma model
I would like to ask if about the structure of the arma model
using least squares and 'sample' my dependent variable the structure for estimating different arma models
sample c ar(1) ma(1) ar(3) ma(3) : is this a correct structure?
sample c ar(1) ar(3) ma(1) ma(3) : is this the same as the above?
sample c ar(3) ma(3) ar(1) ma(1) : is this correct or have the ar to be in increasing order?
Thank you
Thank you
Re: arma model
The order doesn't matter. But it's unusual to have MA(3) or AR(3) without having MA(2) and AR(2).
Re: arma model
So what do you mean? you have to always have in order like 1 2 3...The order doesn't matter. But it's unusual to have MA(3) or AR(3) without having MA(2) and AR(2).
Re: arma model
You don't have to have them in order, but you probably should include all the intermediate orders.So what do you mean? you have to always have in order like 1 2 3...The order doesn't matter. But it's unusual to have MA(3) or AR(3) without having MA(2) and AR(2).
Re: arma model
Sorry to bother you again but if the structure does not matter how come that when I runThanx a lot!!
sample c AR(5) AR(4) AR(9) AR(1) MA(5) MA(4) MA(9) MA(1)
AND
sample c AR(1) AR(4) AR(5) AR(9) MA(1) MA(4) MA(5) MA(9)
gives me a different results and makes the coefficients not significant?
Re: arma model
Significant i mean the probabilities of the coefficients to be under 0,05. This must be that way in order to have a good forecast.Sorry to bother you again but if the structure does not matter how come that when I run
AND
Re: arma model
Hard to say without seeing the workfile.
Re: arma model
Sorry I had it uploaded before!Hello,
thank you
I use the 1781 observations for estimation and 2295 for the forecast
Re: arma model
You might want to post a picture of your output. You should be getting the same results.Significant i mean the probabilities of the coefficients to be under 0,05. This must be that way in order to have a good forecast.Sorry to bother you again but if the structure does not matter how come that when I run
AND
Re: arma model
Ok now I am sending u the two tries.
- second.jpg (258.29 KiB) Viewed 12243 times
- first.jpg (240.66 KiB) Viewed 12243 times
