Error messages from programs with loops
LindaR
Postby LindaR » Thu Oct 06, 2016 3:08 pm
I am using a loop to decompose multiple time series (using X13.SEATS) with permissible errors set to 1000 so it runs through all the series. For almost all the error messages I get in the program log the series are identified as SER{!I} is it possible to capture the actual series number(s)?
Re: Error messages from programs with loops
Postby EViews Gareth » Thu Oct 06, 2016 3:22 pm
Hard to say without knowing exactly what you are doing
LindaR
Postby LindaR » Thu Oct 06, 2016 3:27 pm
Would sending you the program and an example of the program log help?
Postby EViews Gareth » Thu Oct 06, 2016 4:55 pm
Probably.
LindaR
Postby LindaR » Thu Oct 06, 2016 6:02 pm
Hope so,the code and the program log are attached as is the final error message. The specs referenced in the program are at the end of the error message.
log_anzsic tramoseats program_lr_short.txt
(2.12 KiB) Downloaded 247 times
anzsic tramoseats program_lr_short.prg
(2 KiB) Downloaded 265 times
Error_short.docx
(17.15 KiB) Downloaded 265 times
Postby EViews Gareth » Fri Oct 07, 2016 5:30 am
I can see no reason why EViews isn't reporting the series name, rather than ser{!i}, which is weird.
But I guess you could force it by recording it yourself. Off the top of my head, I think I would do something like:
!errcount = @errorcount 'the x13 line here !errcount2 = @errorcount if !errcount2>!errcount then logmsg !i endif
And put a logmode +logmsg somewhere at the top.
LindaR
Postby LindaR » Sun Oct 09, 2016 11:37 pm
Thanks Gareth, your suggestion worked - I now know which series are failing and why/how. All the best, Linda
