Error messages from programs with loops
I am using a loop to decompose multiple time series (using X13.SEATS) with permissible errors set to 1000 so it runs through all the series. For almost all the error messages I get in the program log the series are identified as SER{!I} is it possible to capture the actual series number(s)?
Re: Error messages from programs with loops
Hard to say without knowing exactly what you are doing
Would sending you the program and an example of the program log help?
Hope so,the code and the program log are attached as is the final error message. The specs referenced in the program are at the end of the error message.
- log_anzsic tramoseats program_lr_short.txt
- (2.12 KiB) Downloaded 247 times
- anzsic tramoseats program_lr_short.prg
- (2 KiB) Downloaded 264 times
- Error_short.docx
- (17.15 KiB) Downloaded 265 times
I can see no reason why EViews isn't reporting the series name, rather than ser{!i}, which is weird.
But I guess you could force it by recording it yourself. Off the top of my head, I think I would do something like:
And put a logmode +logmsg somewhere at the top.
!errcount = @errorcount
'the x13 line here
!errcount2 = @errorcount
if !errcount2>!errcount then
logmsg !i
endif
Thanks Gareth, your suggestion worked - I now know which series are failing and why/how. All the best, Linda
