Hello, for all
This is the first time to use EViews statistical program, and I want your help if possible.
I have data for two days for one patient, and my observations or records are taken during 8 hours per day from 12.00 until 20.00 pm. I want to predict the behaviour of the patient in the third day in the same period of time from 12.00 to 20.00 . OK
The first problem is:
** I can not define the Range of the data when I import my excel file to EViews program. !!
The second problem is:
** Can I apply SARIMA model in my data or not?
Best Regards.
Define the Range of data
Re: Define the Range of data
Hello, for all
I attach the data that I want to use in SARIMA MODEL.
* I have data for two days for one patient, and my observation or records are taken durnig 8 hours per day from 12.00 to 20.00 pm. I want to predict the behaviour of the patient in the third day in the same period of time.
** I can not define the range of the data when I import my excel file to Eviews sataistical software, and Which values of S can I use in this case to use SARIM MODEL??
Range of the data, for example. from 12.00d1 to 20.00d2 !!
Thanks a lot for your time.
Best Regards,
Best Regards,
- SARIMA_MODEL.xlsx
- SARIMA_MODEL2016
- (9.56 KiB) Downloaded 271 times
This is the problem
I cant define my range !!
- sarima_model.PNG (44.58 KiB) Viewed 5378 times
Try setting the frequency to intra-day.
Thanks a lot for your cooperation.
I tried to do by intraday, but I have the same promblem to define the Range, because I take my records for each 15 min.
There are another way in order to define my Data Range??
Intraday allows for data at 15 minute intervals.
Thanks for your help.
In estimate equation:
we write the original series ( nonstationary) or the alternative series( dseries) [ stationary series].
Because, when I used the original series gave me the good results. !!
For example,
our_series ar(1) sar(32) ma(1) ma(2) sma(32) sma(64)
dour_series ar(1) sar(32) ma(1) ma(2) sma(32) sma(64)
What is the correct way !
Regards,,
For example,
Regards,,
