I'm suppose to translate this equation (please see below) into Eviews. However, I don't fully understand it.
Doesn't the 'Sum^2'-variable mean that there should be a double-lagged variable?
Can someone please help me explain how I should translate it. If you need more info about the equation, please let me know.
Thank you! :D
/Felix
Please help me translate this equation!!
felixodeen
- ekva.png (2.62 KiB) Viewed 2045 times
Re: Please help me translate this equation!!
Assuming you have series in your panel workfile called Y and F,
and make sure you select fixed cross-section and period effects.
D(Y) D(Y(-1)) D(Y(-2)) D(F) D(F(-1)) D(F(-2))
felixodeen
Thank you so much!
