insurficient number of observations problem
newtoeviews
Postby newtoeviews » Fri Jan 23, 2015 9:12 am
Hi all,
First of all, I have been at the moment quite often here for my master thesis, which requires me to analyse data set. I have as well read topics here related to technical problems and really appreciated all the questions and answers. I actually get the same problems as some people here with "insurficient number of observations" problem. Apprencially, I have checked it again after I read topics here. All my data are correct, no missing observations.
My model is: log(y) = log(x2) log(x3) log(x4) x7 x8 x9
x7, x8, x9 as dummies.
I have panel data set from 2000 to 2013, 84 countries. So I have in total 84x14 = 1176
First, I run the command ls log(y) log(x2) log(x3) log(x4) (x7) (x8) (x9) and got the problem. Then, I managed to run it with only y= x2 x3 x4 x7 x8 x9, I got the result. Or even seperately only with log(y) log(x2); then log(y) log(x3) and so on, the result shows up. It therefore turns out that, I think that I get no problem with data but somehow more with technical things that I really have no clue.
Could you guys please help me to work it out? I really appreciate your help because I am sick of it for the whole week.
With regards, HM
Re: insurficient number of observations problem
Postby startz » Fri Jan 23, 2015 9:18 am
Are some of your variables zero or negative?
Postby EViews Gareth » Fri Jan 23, 2015 9:19 am
Without seeing the workfile, we can only guess. But if I were to guess, I'd say that y, x2, x3 or x4 have zero or negative values.
newtoeviews
Postby newtoeviews » Mon Jan 26, 2015 10:18 am
Thanks for your relies. I attach here by the way the workfile. I actually set all zero values to 1 so that it was supposed to work well, but it was not. Hope you can find the problem here.
I really appreciate your response.
Thanks, HM
final.wf1
(139.75 KiB) Downloaded 463 times
Postby startz » Mon Jan 26, 2015 10:22 am
Works fine using the workfile you posted.
Postby EViews Gareth » Mon Jan 26, 2015 10:32 am
What he said.
newtoeviews
Postby newtoeviews » Mon Jan 26, 2015 10:34 am
I have checked again with log(y) log(x2) log(x3) log(x4) and it gave result but for the whole equation, including x7 x8 x9, it won´t.
Postby startz » Mon Jan 26, 2015 10:38 am
Is this what you did?
newtoeviews
Postby newtoeviews » Mon Jan 26, 2015 10:45 am
There is perhaps some problem of my eviews because I still can not get it. But thank you so much. I know now my data is all correct.
Many thanks and best regards, HM
