Fetching data from Statistics Canada is painfully slow
random_user
Postby random_user » Fri Apr 25, 2025 2:25 pm
First: thanks to the EViews team for adding the Statistics Canada data connectivity feature. It's pretty handy to have!
But, at the moment, its usefulness is severely limited by the fact that it takes a very long time for me to fetch data from it. I will share some details below about that.
mode quiet %data = "INSERT SERIES HERE (SUPPRESSED)" tic table clock !n = 1 For %1 {%data} fetch(db=statcan) {%1} clock(!n,1) = !n clock(!n,2) = @toc !n = !n+1 Next delete df* 'Fetch a second time: tic table clock2 !n = 1 For %1 {%data} fetch(db=statcan) {%1} clock2(!n,1) = !n clock2(!n,2) = @toc !n = !n+1 Next
In this example, I fetched 148 series and it took 26 minutes!
What's interesting is that once the data is fetched, fetching it again shortly after time takes very little time (6.4 seconds).
Is this normal? Is there anything that could be done?
Thanks!
time taken to fetch.png (6.83 KiB) Viewed 68494 times
Re: Fetching data from Statistics Canada is painfully slow
Postby EViews Gareth » Fri Apr 25, 2025 3:03 pm
Its probably just a really large download that StatCan is sending. The reason it is fast the second is that we cache it.
random_user
Postby random_user » Mon Apr 28, 2025 7:20 am
Thanks for the quick response. I understand it may be a very large download, but if there's anything that can be done to make it smaller (or download faster) in the future, that would make the feature much more helpful.
For example, in my case, all these series were being downloaded from the very same table. So, it seems like if an entire table is being downloaded, it's being downloaded repeatedly and unnecessarily? Maybe something to look into....
random_user
Postby random_user » Mon May 05, 2025 1:13 pm
Follow-up question: could the data description also be added fetched?
For example, it would be nice to see a description of the series added as a series attribute.
random_user
Postby random_user » Thu Aug 13, 2026 8:30 am
Hi again,
I'm now having some trouble fetching series from a specific Statistics Canada table. It's not clear if it's an issue on the Statistics Canada side or EViews. But what I can say is that most tables work but at least one does not:
For example:
FETCH(DB=STATCAN) DF_36100491__1.1.1.1.122
This is from table: Table: 36-10-0491-01.
Even when I just try to use the browser, I get the attached error.
UPDATE: it seems to be working now.
