Forecast Evaluation Help
praveen7796
Postby praveen7796 » Fri Jul 13, 2018 4:38 am
I am trying to do a forecast evaluation where the forecast is stored as a series and the observed values are also a series.
I follow the instructions listed here: http://www.eviews.com/help/helpintro.ht ... ation.html, yet I always obtain unusual results.
I am not sure what I am doing wrong. My observed series is titled RETURNSRQ, and the forecast series is titled VOLFORECASTGARCH. The sample range is 2015 to 2018 and i set the training sample to the same( I am not exactly sure about what to set the training sample too.). I filled out this dialog box like this:
dialog box.PNG (15.92 KiB) Viewed 6111 times
This is the result I obtain:
forecast evaluation graph.PNG (11.04 KiB) Viewed 6111 times
I expected the graph to look like this:
expected graph.PNG (28.07 KiB) Viewed 6111 times
The statistics that come with the evaluation are also nonsensical.
I am not sure what I am doing wrong. Any help would be greatly appreciated. For some reason I can't attach my workfile.
Re: Forecast Evaluation Help
Postby EViews Gareth » Fri Jul 13, 2018 7:41 am
Forecast evaluation is for evaluation multiple forecasts of the same series. It looks like you are only evaluating a single series. Thus most of the statistics, and the averaging methods are nonsensical.
praveen7796
Postby praveen7796 » Fri Jul 13, 2018 8:09 am
So how do I obtain forecast evaluation statistics like root mean square error? How can I compare between forecast values and real observations?
Postby EViews Gareth » Fri Jul 13, 2018 8:22 am
You can use the forecast evaluation view for that, but don't include an averaging method.
praveen7796
Postby praveen7796 » Fri Jul 13, 2018 8:53 am
I followed your instructions and obtained this:
I don't understand why its not plotting the full evaluation sample.
Postby EViews Gareth » Fri Jul 13, 2018 8:55 am
Hard to say without having the data.
praveen7796
Postby praveen7796 » Fri Jul 13, 2018 9:00 am
Sorry, I thought I had attached it. I have attached it now. Cheers.
djia.wf1
(951.71 KiB) Downloaded 247 times
Postby EViews Gareth » Fri Jul 13, 2018 9:08 am
Works as expected for me. Ensure your copy of EViews is up to date.
Postby EViews Gareth » Fri Jul 13, 2018 9:09 am
praveen7796
Postby praveen7796 » Fri Jul 13, 2018 9:32 am
I just want to say thanks for all your help. Updating the software did the trick. Sorry for taking up your time.
Cheers.
