I am trying to do a forecast evaluation where the forecast is stored as a series and the observed values are also a series.
I follow the instructions listed here: http://www.eviews.com/help/helpintro.ht ... ation.html, yet I always obtain unusual results.
I am not sure what I am doing wrong. My observed series is titled RETURNSRQ, and the forecast series is titled VOLFORECASTGARCH. The sample range is 2015 to 2018 and i set the training sample to the same( I am not exactly sure about what to set the training sample too.). I filled out this dialog box like this:
This is the result I obtain:
I expected the graph to look like this:
The statistics that come with the evaluation are also nonsensical.
I am not sure what I am doing wrong. Any help would be greatly appreciated. For some reason I can't attach my workfile.
Forecast Evaluation Help
Re: Forecast Evaluation Help
Forecast evaluation is for evaluation multiple forecasts of the same series. It looks like you are only evaluating a single series. Thus most of the statistics, and the averaging methods are nonsensical.
praveen7796
So how do I obtain forecast evaluation statistics like root mean square error? How can I compare between forecast values and real observations?Forecast evaluation is for evaluation multiple forecasts of the same series. It looks like you are only evaluating a single series. Thus most of the statistics, and the averaging methods are nonsensical.
You can use the forecast evaluation view for that, but don't include an averaging method.
praveen7796
I followed your instructions and obtained this: I don't understand why its not plotting the full evaluation sample.You can use the forecast evaluation view for that, but don't include an averaging method.
Hard to say without having the data.
praveen7796
Sorry, I thought I had attached it. I have attached it now. Cheers.Hard to say without having the data.
- djia.wf1
- (951.71 KiB) Downloaded 248 times
Works as expected for me. Ensure your copy of EViews is up to date.
praveen7796
I just want to say thanks for all your help. Updating the software did the trick. Sorry for taking up your time.2018-07-13_090917.png
Cheers.
