Export specific day
eirini
Export specific day
Postby eirini » Mon Dec 21, 2015 6:59 am
i have daily 5day -week prices for my variables. Is there any way to export only the prices for wednesdays beacuse i need to work only with them ?
Thank you!!
Re: Export specific day
Postby EViews Gareth » Mon Dec 21, 2015 8:49 am
Export to what?
eirini
Postby eirini » Mon Dec 21, 2015 9:10 am
By sayng exprot i mean that I want to create another variable which will contain only the prices for Wednesdays.
Postby EViews Gareth » Mon Dec 21, 2015 9:27 am
You have a 5 day daily page. You want to create a new series in that same page that only has data on Wednesdays (the other days are NA)?
If so:
smpl if @weekday = 3 series newseries = x
where X is the name of the original series.
eirini
Postby eirini » Mon Dec 21, 2015 9:39 am
My target is to take from the initial series which is daily(5 day week) the prices for wednesdays in order to calculate the returns betteen them. More specific i have 5 day prices for financial indexes and i want to calculate the returns from Wednesday to Wednesday.
Postby EViews Gareth » Mon Dec 21, 2015 9:51 am
Isn't that exactly what you asked (and received a reply to) here:
http://forums.eviews.com/viewtopic.php? ... 362#p47362
eirini
Postby eirini » Mon Dec 21, 2015 10:08 am
I followed these steps but when i did the special copy i cannot use the option "Frequency coneversion options". it is not highlighted.
Postby EViews Gareth » Mon Dec 21, 2015 10:16 am
Are you sure you created a new weekly page properly?
http://www.eviews.com/Learning/freqconv_a.html
eirini
Postby eirini » Mon Dec 21, 2015 10:34 am
I followed these steps but when i choose below the choice "Merge by" the choice "Date" the selection " Frequency conversion options" is not highlighted. Even when i choose the choice " General match merge criteria" at the right comes up "Match merge options" with the options that you can see in the image that i attached to you. I choose then " Contaction method" the option last but as a weekly page i get the initial daily page.
Postby EViews Gareth » Mon Dec 21, 2015 10:36 am
Post your workfile with both the daily and weekly pages.
eirini
Postby eirini » Mon Dec 21, 2015 10:48 am
untitled1.WF1
(251.42 KiB) Downloaded 396 times
Postby EViews Gareth » Mon Dec 21, 2015 10:55 am
Your weekly page is not weekly. It is daily.
eirini
Postby eirini » Mon Dec 21, 2015 10:57 am
This is my issue...i cannot create it....what am i doing wrong?
Postby EViews Gareth » Mon Dec 21, 2015 11:02 am
Click on the New Page tab, select Specify by Frequency/Range..., then change the frequency to be weekly.
eirini
Postby eirini » Tue Dec 22, 2015 2:28 am
I followed exactly what you proposed me to do but i noticed that in my new weekly page although the prices are for Wednesdays the dates are not right. More specific for example the price for 1/10/1997 now has a different date which is 4 days earlier, in my example becomes 1/04/1997. I noticed also that changing the start date each time the new weekly page that is created has prices for different days each time. For example when i choose as a start date 1/1/1980(tuesday) then the weekly page contains all the prices for Mondays, but when i choose as a start date 1/2/1980 then the weekly page contains all the prices for Tuesdays and when i choose as a start date 1/3/1980(tuesday) then the weekly page contains all the prices for Wednesdays. In three cases the prices are not follow the right date. What am i missing?
Thank you a lot!!
