i need to do the monday effect. can you help to advise the attached excel file is correct
and how to import to eviews 8. thanks
monday effect
monday effect
- monday effect.xlsx
- (20.98 KiB) Downloaded 260 times
Re: monday effect
Just dragging that file onto EViews 8 should work fine.
Re: monday effect
thanks so much
can you help to take a look, the attached result is correct ?
- Monday effect ls.pdf
- (6.73 KiB) Downloaded 249 times
- monday effect arch.pdf
- (7.09 KiB) Downloaded 273 times
Re: monday effect
I cannot answer that.
Re: monday effect
sorry. i want to ask the setting is correct. but i have another issue. some daily return is zero, becuase that is holiday. can you advise how to fix this. thanks.
Re: monday effect
smpl if return<>0
