monday effect
jadechan
monday effect
Postby jadechan » Sun Aug 23, 2015 11:40 pm
i need to do the monday effect. can you help to advise the attached excel file is correct
and how to import to eviews 8. thanks
monday effect.xlsx
(20.98 KiB) Downloaded 260 times
Re: monday effect
Postby EViews Gareth » Mon Aug 24, 2015 7:19 am
Just dragging that file onto EViews 8 should work fine.
jadechan
Re: monday effect
Postby jadechan » Mon Aug 24, 2015 9:08 am
thanks so much
can you help to take a look, the attached result is correct ?
Monday effect ls.pdf
(6.73 KiB) Downloaded 248 times
monday effect arch.pdf
(7.09 KiB) Downloaded 272 times
Re: monday effect
Postby EViews Gareth » Mon Aug 24, 2015 9:13 am
I cannot answer that.
jadechan
Re: monday effect
Postby jadechan » Wed Aug 26, 2015 2:11 am
sorry. i want to ask the setting is correct. but i have another issue. some daily return is zero, becuase that is holiday. can you advise how to fix this. thanks.
Re: monday effect
Postby startz » Wed Aug 26, 2015 6:31 am
smpl if return<>0
