BANKSCOPE data restructure to panel data
lana
Postby lana » Thu Mar 05, 2015 12:39 am
I get data from bankscope and I don't know how to re-structure it into panel data. Could any one help me please :cry: :cry: :cry: :cry:
thank you
trubador
Did you use forum search?
Re: BANKSCOPE data restructure to panel data
Postby trubador » Thu Mar 05, 2015 4:06 am
lana
Postby lana » Thu Mar 05, 2015 5:17 am
thank you for your responde. actually my data look like in the attachement capture2 but when I try to import the data into eviews I don't know what should I put in "cross section ID series" and "date series" (attachement capture1")
capture1.docx
(198.73 KiB) Downloaded 417 times
capture2.docx
(190.04 KiB) Downloaded 443 times
Postby EViews Gareth » Thu Mar 05, 2015 8:50 am
Whatever the name of the column containing dates you put in the date series box, and the name of the column containing cross-sections you put in the cross section series box.
lana
Postby lana » Thu Mar 05, 2015 8:58 am
that's what I did on the pictures (PAYS.CODE = country code) but it didn't work. I get an error message (PAYS.CODE) not defined) ! . but i got it in the data
Postby EViews Gareth » Thu Mar 05, 2015 9:20 am
You can't have a "." in an EViews series name. Try pays_code
lana
Postby lana » Thu Mar 05, 2015 9:35 am
It works but now I have an other error message (repeated values found in source id series)!
actually I have for the same periode (2006-2014) data for each bank in each country (please can you check picture 2)
thank you
Postby EViews Gareth » Thu Mar 05, 2015 10:03 am
So you have a 3D panel?
lana
Postby lana » Thu Mar 05, 2015 10:20 am
I don't know what is it. believe me it's my first experience with the panel data. can you explain me what is it and how can I treat it using eviews
thanks
Postby EViews Gareth » Thu Mar 05, 2015 10:23 am
Traditional panels are 2 dimensional. You have a time index and a cross-section index. Nearly all econometric theory works only with 2D panels.
lana
Postby lana » Thu Mar 05, 2015 12:18 pm
thank you for the explanation. I realize that I was wrong it is just banks and years (without coutry). I've juste tried now but it's the same ("repeated values in the ressource id series)!!
lana
Postby lana » Thu Mar 05, 2015 2:02 pm
thank you for your help. I find the solution finally!! :D
dmauricio
Postby dmauricio » Tue Aug 04, 2015 5:29 am
And the solution was??? ^
Thank you, I'm going through the same issue...
StudentGroningen
Postby StudentGroningen » Wed Sep 23, 2015 7:04 am
Hi all, and lana in particular,
how did you manage to get the excel model as in capture2.docx??
I am struggling with my bankscope export, because I don't know how to import it to EViews (it is not like one of the examples on http://forums.eviews.com/viewtopic.php?f=7&t=74
My excel model looks like this (example):
Bank..........Total assets 2014.......Total assets 2013.......Total asset 2012......Equity 2014........Equity 2013......Equity 2012 etc
Citigroup............80........................70..........................60...................40....................35..................30
JP Morgan...........70........................60..........................50...................30....................25..................20
etc
I have 4939 banks, 11 variables and 15 years in total. Do you know a way to import this file into EViews? Or how to restructure my Excel model in a way that it can be imported easily?
Thanks!
