I am running a panel regression, the R^2 between Eviews and Excel is kind of different.
R^2 Eviews: -0.033164
R^2 Excel: 0.184428
To my knowledge, SST=SSR+SSE and all these value are positive. Two questions here is:
1. Why R^2 in Eviews could be negative?
2. Why there is such different between Excel Regression and Eviews in calculating R^2 while all coefficients between two programs are identical?
I included:
- Eviews file. Just take a look at eq01.
- Excel file.
+ Sheet1: all data
+ Sheet2: sample used for estimate Regression the same as sample used in Eviews. Data filter: GISC=4 and doup=1
Thank you for viewing
Unrelated questions:
1. Can we run fixed effect regression without constant c?
2. In Estimate Equation, how can we filter data >90th percentile and data<10th percentile
Different result Eviews vs Excel
quoctruongphan
- NetDIss.xlsx
- (685.82 KiB) Downloaded 296 times
- netdiss.wf1
- (405.31 KiB) Downloaded 240 times
quoctruongphan
Re: Different result Eviews vs Excel
Hope someone can help this topic,
Many thanks
Many thanks
1. You have no constant. R^2 can go negative if you have no constant.
2. Without knowing how Excel calculates R^2 in the no-constant model, it is hard to know how they are differing.
3. You can specify an equation with fixed effects without a constant, but EViews will add it in for you.
4. Use the sample
4. Use the sample
quoctruongphan
Thank you for your answer but:1. You have no constant. R^2 can go negative if you have no constant.
4. Use the sample
SSE between Eviews & Excel have the same estimation: 5.06E+08 but different SSR:
+ Eviews: SSR=2383.93
+ Excel: SSR=1.14E+08
and general formula to calculate R^2 is: SSR/SST = SSR/(SSR+SSE)
Here, no matter how substituting, there is no way to obtain a negative R^2 here
Eviews: 2383/(2383+5.06E+08) ~ 3.84E-06 (non negative)
Exel : 1.14/(1.14+5.06) = 0.18
I don't know if there is any mistake in my statement, if not then can you explain more how could without constant, R^2 can be negative?
That formula doesn't apply. To see how EViews calculates R-squared, see User Guide II.
