Stacked bar graph
Stacked bar graph
Postby tvonbrasch » Tue Oct 09, 2012 6:57 am
I have a problem when making a stacked bar graph. The series (see attached workfile) in the group include both negative and positive values.
If i make a stacked bar graph, the graph does not show the correct values. see graph01 and group .
However, if i first make a single bar graph with data contracted by e.g., mean, and then afterwards I create a stacked bar graph, I get the desired result (see graph02correct and group1).
Is this a bug?
Sincerely,
Thomas von Brasch
Eviews 7.2 October 3
bargraph.WF1
(18.56 KiB) Downloaded 925 times
EViews Esther
Re: Stacked bar graph
Postby EViews Esther » Tue Oct 09, 2012 11:32 am
This is not a bug. The way EViews creates a stacked bar graph (i.e. stacking positive & negative values) is different from Excel.
You will get the desired result by choosing the checkbox of the Stacked bar graphs (Graph Elements -> Bar-Area-Pie -> Checkbox: Stacked bar graphs ) option.
Postby tvonbrasch » Tue Oct 09, 2012 11:30 pm
perfect, thanks,
miorinnovo
Postby miorinnovo » Fri May 13, 2022 6:25 am
Is there a way to do this by coding it? I'm trying to do a mixed graph with a line and the rest stack bars but the 'stackedbar(2,3,4)' command seems to default to the non-excel way.
thanks
Postby EViews Gareth » Fri May 13, 2022 8:55 am
mygraph.options stackposneg
miorinnovo
Postby miorinnovo » Fri May 13, 2022 5:48 pm
Thanks, maybe i have the wrong first part though.
Doing this :
mygraph.mixed stackedbar(1) line(2) mygraph.options stackposneg
It gives me an error saying options is not a valid view
