I have a problem when making a stacked bar graph. The series (see attached workfile) in the group include both negative and positive values.
If i make a stacked bar graph, the graph does not show the correct values. see graph01 and group .
However, if i first make a single bar graph with data contracted by e.g., mean, and then afterwards I create a stacked bar graph, I get the desired result (see graph02correct and group1).
Is this a bug?
Sincerely,
Thomas von Brasch
Eviews 7.2 October 3
Stacked bar graph
Stacked bar graph
- bargraph.WF1
- (18.56 KiB) Downloaded 923 times
EViews Esther
Re: Stacked bar graph
This is not a bug. The way EViews creates a stacked bar graph (i.e. stacking positive & negative values) is different from Excel.
You will get the desired result by choosing the checkbox of the Stacked bar graphs (Graph Elements -> Bar-Area-Pie -> Checkbox: Stacked bar graphs ) option.
- eg.PNG (43.62 KiB) Viewed 16736 times
perfect, thanks,
miorinnovo
Is there a way to do this by coding it? I'm trying to do a mixed graph with a line and the rest stack bars but the 'stackedbar(2,3,4)' command seems to default to the non-excel way.
thanks
mygraph.options stackposneg
miorinnovo
Thanks, maybe i have the wrong first part though.Code: Select all
Doing this :
mygraph.mixed stackedbar(1) line(2)
