how to put data on right oreder in order to run regression?
helen757
Postby helen757 » Wed Nov 23, 2011 3:40 am
hello Mr or Miss,
Would you help to put the data on the right order?
Every time i put the data on the screen i can not see dependent variable (because it must be with icon abc)
thank you in advance
Helen
for ols model.xls
(34.5 KiB) Downloaded 303 times
Re: how to put data on right oreder in order to run regressi
Postby startz » Wed Nov 23, 2011 7:47 am
Perhaps you could tell us what you're doing in EViews.
helen757
Postby helen757 » Thu Nov 24, 2011 12:30 am
i have 2 countries uk and kz. the equation i wanna run is as next for each country: lnincome=years of schooling+lnpopulation+age group+male+Et
So what is the right order of the variables written on excel attached for panel data or cross-sectional time series (which is appropriate)? What is the best way to figure out?
Postby startz » Thu Nov 24, 2011 8:35 am
The order of the variables doesn't matter. Just include an additional variable identifying the country.
helen757
Postby helen757 » Thu Nov 24, 2011 8:46 pm
thank you very much. But my Eviews 7 recognizes country as the dependent variable, where i want income to be the dependent one.
So, how can i change it?
Postby startz » Thu Nov 24, 2011 10:12 pm
Show us the command you're using.
helen757
Postby helen757 » Sun Dec 04, 2011 8:44 pm
Dear startz,
Thanks for your time and knowledge contribution.
Now i have another question.The results of the ADF and PP tests
are more negative than critical values. Therefore i reject the null hypothesis.
But what if in KPSS test it is less positive than critical values. Do i reject the null hypothesis or not?
Kwiatkowski-Phillips-Schmidt-Shin test statistic 0.062004
Asymptotic critical values*: 1% level 0.216000
5% level 0.146000
10% level 0.119000
Postby startz » Sun Dec 04, 2011 10:07 pm
No.
helen757
Postby helen757 » Mon Dec 05, 2011 1:12 am
Just to be confident i need to ask a question.
According to results of KPSS i do not reject the null hypothesis?
If it was more positive than critical values, i would reject the null.
(it would cover critical values by being on top of critical values)
is that right?
helen757
Postby helen757 » Mon Dec 05, 2011 2:20 am
the results of adf and pp tests should give the same result, however kpss should attract the opposite in order to meet right conclusion.
Is that right?
Postby startz » Mon Dec 05, 2011 7:32 am
You got it all right.
helen757
Postby helen757 » Sun Dec 11, 2011 9:59 pm
hello startz,
I have some problems in understanding results of Johansen cointegration test.
I was wondering if you could help me in interpreting them.
The results attached.
helen
Cointegration results (option 6).pdf
(110.78 KiB) Downloaded 298 times
