error 1073741824
bparksb
error 1073741824
Postby bparksb » Tue Nov 26, 2013 8:22 am
I am getting an ERROR 1073741824
LS DRINK C SPIR_TAX LOG(SPIR_TAX) 1/SPIR_TAX SPIR_TAX^2
works fine but
LS DRINK C 1/SPIR_TAX
gets a dialogue box with error 1073741824
Data set at
http://econ413.wustl.edu/eviews_1073741824.wf1
Eviews 8 standard edition Nov 19 build
Re: error 1073741824
Postby EViews Gareth » Tue Nov 26, 2013 8:59 am
I cannot replicate this. Could you state exactly what you did?
Postby startz » Tue Nov 26, 2013 9:37 am
I replicated Bob's bug by opening the workfile and typing in the command. I did get another, apparently random, number in the alert box. This was on my home machine. On my work machine the code runs fine. (Both are the current build of EViews.)
Postby EViews Gareth » Tue Nov 26, 2013 9:48 am
Could you do the supportinfo command on both machines, and paste results here (or email)?
bparksb
Postby bparksb » Tue Nov 26, 2013 1:25 pm
Here is my support info
PRODUCT
Version: EViews 8 32-bit
Build date: Nov 19 2013
Serial Number:
LICENSING
Standalone : C:\Documents and Settings\All Users\Application Data\IHS EViews\EViews\8.00.000\license.txt
PATHS
Installation path: C:\Program Files\EViews 8
Working path: G:\E413\ADATA
INI path: C:\Documents and Settings\xxxxxxx\Application Data\Quantitative Micro Software\EViews
DB INI path: C:\Documents and Settings\xxxxxxx\Application Data\Quantitative Micro Software\EViews
Help path: C:\Program Files\EViews 8\Help Files
ENVIRONMENT
OS: Windows XP Service Pack 3 32Bit
Total Address Space: 1453476k
VMEM Block Space: 1228324k
VMEM Space In Use: 24892k
EViews Address Space: 1206888k
EV Add Space In Use: 3456k
Cores in use: 2
bparksb
Postby bparksb » Tue Nov 26, 2013 5:43 pm
I just did a reboot and opened Eviews as the first program I obtained identical results - error number is the same 1073741824
Support info same.
LS DRINK C 1/SPIR_TAX log(spir_tax)
fails with the same error while
LS DRINK C log(spir_tax) 1/SPIR_TAX
produces answers.
Postby EViews Gareth » Tue Nov 26, 2013 8:08 pm
Thanks. We'll look into it.
Postby EViews Gareth » Fri Dec 06, 2013 9:36 am
Recent patch might fix it.
bparksb
Postby bparksb » Fri Apr 25, 2014 10:41 am
I have the same error with a new data set. This time
ls medal c gdp gdp^2 1/gdp log(gdp)
obtains the error while
ls medal c gdp gdp^2 log(gdp) 1/gdp
works!
http://econ413.wustl.edu/hinesa-error.wf1
does not. Current support info
PRODUCT
Build date: Apr 5 2014
Serial Number: xxxxxxxxx
LICENSING
Standalone xxxxxx: C:\Documents and Settings\All Users\Application Data\IHS EViews\EViews\8.00.000\license.txt
PATHS
Installation path: c:\program files\eviews 8
INI path: c:\documents and settings\xxx\application data\quantitative micro software\eviews
DB INI path: c:\documents and settings\xxx\application data\quantitative micro software\eviews
Help path: c:\program files\eviews 8\help files
ENVIRONMENT
Total Address Space: 1453412k
VMEM Space In Use: 24304k
EV Add Space In Use: 2868k
Cores in use: 2
Postby EViews Glenn » Fri Apr 25, 2014 5:07 pm
Good news (sort of).
We've been able to replicate the error. The reason that Gareth wasn't able to see the error is, I believe, due to differences in the global evaluation settings on the relevant machines.
In the dialog for Options/General Options/Auto-series there is a setting for whether to report auto-series evaluation errors in statistical views and procedures. Presumably, bparksb has this set to "Report evaluation errors" and Gareth has it set to "Treat evaluation errors as NAs". EViews is attempting to report the error on bparks' machine as requested, but the error code "1073741824" is not a particularly instructive error message :D. Clearly that has to be fixed, and we'll look at it.
For now, if bparks changes the Global Options setting to Gareth's, the estimation will go through, dropping the missings as required. We'll get the error message cleaned up. Thanks for your patience on this one. It wasn't an easy one to replicate.
bparksb
Postby bparksb » Thu May 01, 2014 4:33 am
THANKS - that did fix it. Bob
