Renaming cross-sections in the id01 variable
yzerman
Postby yzerman » Mon Aug 26, 2013 11:26 am
I have a panel file and I'd like to rename some of my cross-sections, as listed in the id01 variable. Eviews tells me that I cannot edit those cells. Is there a workaround without having to unstructure and restructure my workfile?
Re: Renaming cross-sections in the id01 variable
Postby EViews Gareth » Mon Aug 26, 2013 11:29 am
The only way is to unstructure, restructure.
Or, you could create a new alpha series equal to id01, change the ones you want to change, then restructure to use the new alpha series.
