dear forum,
Do you know if I can adjust the sample "size" in Eviews in panel format (cross sectional units of observation, not the sample period)?
Let's say I want to get rid of units that have large missing values. which command should I use? I really appreciate any feedback on this issue.
best regards,
Sample Size
Re: Sample Size
Could you provide more details? Your question is open to interpretation.
Re: Sample Size
dear Eviews Gareth,
in my data set, I have 39 units of observations (firms) across a range of variables.
When I look at the file in the excel spread sheet, I see that some firms have lots of missing values (n.a). I beleive that is creating a problem for my analysis. I was told that data has to be as complete as possible (balanced and few missing values)
I want to get rid of those units of analysis with lots of na's. In other words, i want to reduce sample size? How can I reduce sample size?
Hope this is clear. I really need your help.
as always, appreciated.
lnp3
M.D
lnp3
M.D
Re: Sample Size
For 99% of statistical analysis in EViews, it will drop the NAs for you. You don't need to change the sample.
Re: Sample Size
dear Eviews Gareth,
on a related topic, I tried to run dynamic OLS in a panel framework. However, I receive this error:
It says " no valid observations after removing cross-sectons with estimation errors"
There is no problem running Fully Modified analysis (FMOLS). It gives problems with Dynamic OLS.
What can be the reason of this problem?
I really appreciate your help.
Re: Sample Size
You probably don't have enough observations.
Re: Sample Size
dear Eviews,
For dynamic OLS, I think I need longer time period and larger data set. My period is 1997-2012 (with a total of 624 observations), 39 units of observation.
I beleive that missing values are complicating the problem. Some cross sections have insufficient observations.
Do you think I should use the method of "interpolation"... Eviews says that this procedure " fills in missing values or na's within a series by interpolating them from values that are non-missing"
Do you think it is necessary and if so will you help me interpolate my series? I opened a series but could not find the command in Eviews 8 Proc/Interpolate..
Re: Sample Size
I include the 1 dummy variable and 1 interaction term while estimating the fmols and it show he same statement. Any suggestion to estimate the model which is cointegrated in the panel pedroni cointegration test?You probably don't have enough observations.
Thanks.
