Sample Size
lnp3
Sample Size
Postby lnp3 » Mon Aug 12, 2013 1:05 pm
dear forum,
Do you know if I can adjust the sample "size" in Eviews in panel format (cross sectional units of observation, not the sample period)?
Let's say I want to get rid of units that have large missing values. which command should I use? I really appreciate any feedback on this issue.
best regards,
Re: Sample Size
Postby EViews Gareth » Mon Aug 12, 2013 1:20 pm
Could you provide more details? Your question is open to interpretation.
lnp3
Re: Sample Size
Postby lnp3 » Mon Aug 12, 2013 2:53 pm
dear Eviews Gareth,
in my data set, I have 39 units of observations (firms) across a range of variables.
When I look at the file in the excel spread sheet, I see that some firms have lots of missing values (n.a). I beleive that is creating a problem for my analysis. I was told that data has to be as complete as possible (balanced and few missing values)
I want to get rid of those units of analysis with lots of na's. In other words, i want to reduce sample size? How can I reduce sample size?
Hope this is clear. I really need your help.
as always, appreciated.
lnp3
M.D
Re: Sample Size
Postby EViews Gareth » Mon Aug 12, 2013 3:01 pm
For 99% of statistical analysis in EViews, it will drop the NAs for you. You don't need to change the sample.
lnp3
Re: Sample Size
Postby lnp3 » Mon Aug 12, 2013 3:05 pm
that is good to know indeed..
lnp3
Re: Sample Size
Postby lnp3 » Mon Aug 12, 2013 3:09 pm
dear Eviews Gareth,
on a related topic, I tried to run dynamic OLS in a panel framework. However, I receive this error:
It says " no valid observations after removing cross-sectons with estimation errors"
There is no problem running Fully Modified analysis (FMOLS). It gives problems with Dynamic OLS.
What can be the reason of this problem?
I really appreciate your help.
Re: Sample Size
Postby EViews Gareth » Mon Aug 12, 2013 4:19 pm
You probably don't have enough observations.
lnp3
Re: Sample Size
Postby lnp3 » Tue Aug 13, 2013 6:45 am
dear Eviews,
For dynamic OLS, I think I need longer time period and larger data set. My period is 1997-2012 (with a total of 624 observations), 39 units of observation.
I beleive that missing values are complicating the problem. Some cross sections have insufficient observations.
Do you think I should use the method of "interpolation"... Eviews says that this procedure " fills in missing values or na's within a series by interpolating them from values that are non-missing"
Do you think it is necessary and if so will you help me interpolate my series? I opened a series but could not find the command in Eviews 8 Proc/Interpolate..
Kwong
Re: Sample Size
Postby Kwong » Wed May 11, 2016 8:36 am
I include the 1 dummy variable and 1 interaction term while estimating the fmols and it show he same statement. Any suggestion to estimate the model which is cointegrated in the panel pedroni cointegration test?
Thanks.
