I just met a strange problem in Eviews 7 due to unknown reason.
I was trying to add another eviews database to the registry through Options=>Database Registry=> Add New Entry.
However, after I added a new database, the old registered databases all disappeared. I must have done something wrong, but can't figure it out myself.
Is there a way I can retrieve all the previous database I registered? I was trying to do so by retrieving an old file: c:\Program Files\Eviews 7\ev_dbase.dll. But that file seems not including the registry info.
Thanks in advance.
Database registry problem.
Re: Database registry problem.
The EViews registry is stored in the file called evDB.ini in your ini directory (you can find the location of that from Options->General Options->File Locations).
Thanks so much. It worked!
