bug with fracdiff
ecofin
bug with fracdiff
Postby ecofin » Sat May 11, 2013 2:58 am
hi, when I use fracdiff for example:
degree of defferencing= 0 and degree of seasonal=12
but when i use genr dclose=d(close,0,12) is not the same result :!:
this is the out put of image.
out put of my work file
11-05-2013 11-53-42.png (43.88 KiB) Viewed 14101 times
ecofin
Re: bug with fracdiff
Postby ecofin » Sat May 11, 2013 3:09 am
out put of work file
11-05-2013 12-08-24.png (41.74 KiB) Viewed 14097 times
trubador
Did you use forum search?
Postby trubador » Sat May 11, 2013 3:26 pm
The corrected version will probably be posted in a few days, but you can also get rid of the bug if it's urgent. Just change the Line 76 of the original code:
series {%name+%outname} = d({%name},0,!s)
with the following:
%newname=%name+%outname series {%newname} = d({%name},0,!s)
ecofin
Postby ecofin » Sun May 12, 2013 12:26 am
thank you very much :D
ecofin
Postby ecofin » Sun May 12, 2013 4:20 am
hello, I have change the Line 76 but it's not the same resolt.
trubador
Postby trubador » Sun May 12, 2013 12:58 pm
Is it because you have changed the name of the original program file instead of overwriting it?
ecofin
Postby ecofin » Mon May 13, 2013 12:39 am
it is the same result, ok I will wait for the corrected version
thank you very much.
trubador
Postby trubador » Mon May 13, 2013 3:55 am
In the meantime, just leave the "Degree of differencing" box empty instead of assigning zero.
ecofin
Postby ecofin » Tue May 14, 2013 3:49 am
ok! Now it is the same result, thank you very much.
trubador
Postby trubador » Tue May 14, 2013 5:03 am
The new version is uploaded, by the way...
ecofin
Postby ecofin » Wed May 15, 2013 2:27 am
fracdiff works very well now. thanks! :D
Return to “Add-in Support”
