Line graph, different legends
uwhusky
Postby uwhusky » Mon May 06, 2013 10:58 pm
How do I create a line graph which is marked by three different legends (solid, dotted and long dotted lines) according to the specific periods I define? Specifically, I would like to show three different regimes of periods on the UK real exchange rate, see the attachment. Three regimes are defined by two periods when exchange rates are below -.3 (regime 1), above -0.3 (regime 2) and the periods after 1992Q3 (regime 3). How do I create the same graph that is ploted in Excel? Thanks.
3regimesTimeY_20130318.pdf
(316.78 KiB) Downloaded 440 times
Re: Line graph, different legends
Postby EViews Gareth » Tue May 07, 2013 7:50 am
You'd have to create three different series, with each series only containing values for certain periods. Then chart them together.
uwhusky
Postby uwhusky » Tue May 07, 2013 10:44 pm
Thanks. I tried to create three different series, and plot them togather in a line graph, but it turns out to be some discountious lines (see the attached workfile). How can I join these lines into a continuous line without jump points as I created in Excel?
uk_regimes.WF1
(15.5 KiB) Downloaded 362 times
Postby EViews Gareth » Wed May 08, 2013 7:58 am
You'd have to fill in those values in the series too. Tricky.
