descriptive statistic - weekend effect
Marketa
Postby Marketa » Sat Apr 13, 2013 11:22 am
I would like to ask you if is there any possibility to import data with different long time series. I tried to analyse a weekend effect for monday - friday but each year has different number of data. For examle in the year 2012 monday has (47) days, tuesday (50), wednesday (51), thursday (51), friday (51). How to import data to EViews 7? It´s to hard to analyse each day of week for each year.
Thank you for your reply
Marketa
Re: descriptive statistic - weekend effect
Postby EViews Gareth » Sat Apr 13, 2013 9:49 pm
I'm confused. What structure does your data have? Why is it difficult to bring into EViews?
Marketa
Postby Marketa » Sun Apr 14, 2013 7:00 am
let´s check example bellow:
date monday date tuesday date wednesday date thursday date friday 4.1.2010 1,954071699 5.1.2010 0,383200949 6.1.2010 0,309925808 7.1.2010 0,219745641 8.1.2010 0,424042829 11.1.2010 0,318668586 12.1.2010 -1,06077448 13.1.2010 0,80659384 14.1.2010 0,247065386 15.1.2010 -1,239165864 25.1.2010 0,60296246 19.1.2010 1,174165392 20.1.2010 -1,541302695 21.1.2010 -2,142482578 22.1.2010 -2,025402445 1.2.2010 1,791725306 26.1.2010 -0,635539619 27.1.2010 0,103669467 28.1.2010 -1,123748658 29.1.2010 -1,057898986 8.2.2010 -1,020708859 2.2.2010 1,321240765 3.2.2010 -0,831732036 4.2.2010 -3,68445375 22.2.2010 -0,06665829 11.2.2010 1,160545588
when i want to put it together into Eviews I have to specify number in each column - see attachments (number of observations) - it differs for each day
I suppose that it will be undated data series because each day of the week has different date
So am I right? Is this process by undated data series?
It is not working when I state number of observations as 6 (because of the thurday and monday), others days of the week has smaller number of dates.
The issue is that I have to put each day for each year separately and it takes long time.
Due to this fact I tried to put all days together for each year and test it together for descriptive statistic.
Postby EViews Gareth » Mon Apr 15, 2013 8:02 am
Could you post the data file? This should be easy...
Marketa
Postby Marketa » Tue Apr 16, 2013 11:15 am
of course :)
the file is too large for direct upload to this forum. So I put it to Dropbox, see this link:
https://dl.dropboxusercontent.com/u/142 ... 202010.xls
Thank you
Postby EViews Gareth » Tue Apr 16, 2013 11:34 am
Ha, that's one of the craziest data formats I've seen :)
There are lots of ways to do it. I think this is the easiest (in EV7 or 8).
wfcreate d5 2010 2010 import(mode=ms) "nya 2010.xls" range="a1:b53" @id date @destid @date @rename monday x import(mode=ms) "nya 2010.xls" range="c1:d53" @id date @destid @date @rename tuesday x import(mode=ms) "nya 2010.xls" range="e1:f53" @id date @destid @date @rename wednesday x import(mode=ms) "nya 2010.xls" range="g1:h53" @id date @destid @date @rename thursday x import(mode=ms) "nya 2010.xls" range="i1:j53" @id date @destid @date @rename friday x
Marketa
Postby Marketa » Wed Apr 17, 2013 9:27 am
this information is not useful for me. The reason is that I want to have 5 columns - for each day descriptive statistic separately. Not all data in one column together :(
Postby EViews Gareth » Wed Apr 17, 2013 9:29 am
That's sort of weird, but, if you insist that's what you want, simply lop off the "@rename" bit at the end of each import command.
