I am trying to forecast from realized garch logl object, so I create a model object from it. I solved the model using actual scenarios. Am I right to interpret that to solve the model is to forecast it? If so, how do I obtain a forecast series from it?
Forecast series from model solution
Re: Forecast series from model solution
Yes, solving the model is forecasting. Solve the baseline scenario. Then you'll be left with a series called Y_0 (assuming your dependent variable was called Y) in your workfile, containing the forecast values.
felix.casares
im from Ecuador.
please, how works the model solution and it forecast?
thanks
im from Ecuador.
thanks
