Forecast series from model solution
mengk
Postby mengk » Mon Mar 18, 2013 1:54 am
I am trying to forecast from realized garch logl object, so I create a model object from it. I solved the model using actual scenarios. Am I right to interpret that to solve the model is to forecast it? If so, how do I obtain a forecast series from it?
Re: Forecast series from model solution
Postby EViews Gareth » Mon Mar 18, 2013 8:26 am
Yes, solving the model is forecasting. Solve the baseline scenario. Then you'll be left with a series called Y_0 (assuming your dependent variable was called Y) in your workfile, containing the forecast values.
felix.casares
Postby felix.casares » Thu Jul 04, 2013 8:47 am
im from Ecuador.
please, how works the model solution and it forecast?
thanks
Return to “Models”
