How can I identify the breakpoint dates
alps
Postby alps » Sun Feb 24, 2013 8:14 am
Is there a way of finding where the breakpoints are in Andrews-Quandt test? Or should I do chow test to see if any of the suspected dates are the breakpoints.
Also, is there a way of doing the AQ test and imposing restrictions on the parameters e.g. them being zero?
Alps
Re: How can I identify the breakpoint dates
Postby EViews Gareth » Sun Feb 24, 2013 8:52 am
The test output shows the location of the most likely break.
alps
Postby alps » Sun Feb 24, 2013 11:22 am
thanks very much for your quick response. Yes, I just noticed. Is there a way of testing the paramater stability and test if those parameters are zero at the same time?
Postby EViews Gareth » Sun Feb 24, 2013 12:12 pm
No.
Postby EViews Glenn » Mon Feb 25, 2013 12:26 pm
If you are testing for zero, isn't that also stable?
