Is there a way of finding where the breakpoints are in Andrews-Quandt test? Or should I do chow test to see if any of the suspected dates are the breakpoints.
Also, is there a way of doing the AQ test and imposing restrictions on the parameters e.g. them being zero?
Alps
How can I identify the breakpoint dates
Re: How can I identify the breakpoint dates
The test output shows the location of the most likely break.
thanks very much for your quick response. Yes, I just noticed. Is there a way of testing the paramater stability and test if those parameters are zero at the same time?
If you are testing for zero, isn't that also stable?
