Dear all =)
I've some troubles with a maximum likelihood estimation:
I've an equation for the estimation, however, one variable should be simultaneously calculated via the 'model'-feature (model calc ---- calc.append ---- calc.solve). How can I incorporate this calculation in the ml estimation?
thanks!
Maximum Likelihood + Model
Re: Maximum Likelihood + Model
If you're using the LogL object, you cannot do that.
You could try using the Optimize command in EViews 8.
ok thanks... actually I'm still using Eviews 6.. =( so I guess there is no possibility to do this in Eviews 6 right?
Regarding the "optimize" command in E8, is this still a ML estimation or is it in some way a maximization?
thanks..
thanks..
It is general optimization, including maximisation. If you give it a likelihood function, it is ML.
