Maximum Likelihood + Model
ku_al
Postby ku_al » Fri Feb 08, 2013 3:11 am
Dear all =)
I've some troubles with a maximum likelihood estimation:
I've an equation for the estimation, however, one variable should be simultaneously calculated via the 'model'-feature (model calc ---- calc.append ---- calc.solve). How can I incorporate this calculation in the ml estimation?
thanks!
Re: Maximum Likelihood + Model
Postby EViews Gareth » Fri Feb 08, 2013 9:26 am
If you're using the LogL object, you cannot do that.
You could try using the Optimize command in EViews 8.
ku_al
Postby ku_al » Fri Feb 08, 2013 10:21 am
ok thanks... actually I'm still using Eviews 6.. =( so I guess there is no possibility to do this in Eviews 6 right?
Regarding the "optimize" command in E8, is this still a ML estimation or is it in some way a maximization?
thanks..
Postby EViews Gareth » Fri Feb 08, 2013 10:23 am
It is general optimization, including maximisation. If you give it a likelihood function, it is ML.
ku_al
Postby ku_al » Fri Feb 08, 2013 10:25 am
ok thanks!
