Can eviews performs inervention and outier analysis?
masxupeng
Postby masxupeng » Sun Dec 09, 2012 4:53 am
Re: Can eviews performs inervention and outier analysis?
Postby EViews Gareth » Sun Dec 09, 2012 9:40 am
There's nothing built in (other than leverage plots and influence statistics).
Postby EViews Glenn » Mon Dec 10, 2012 12:20 pm
Intervention analysis using various dummy variable specifications can be easy-to-do. It really depends on how you want to specify the mean.
R. Jassy
Postby R. Jassy » Wed Apr 17, 2013 7:49 am
yes, but still i cannot figure out how to input the SARIMA-intervention model with the following?
can you please help
(\frac{\omega_1 B}{1-\delta B}+\frac{\omega_2 B}{1-B})D\_2007M03 + (\omega_0 - \frac{\omega_1 B}{1-\delta B}+\frac{\omega_2 B}{1-B})D\_2009M01
Thank you
AASA
Postby AASA » Wed Sep 30, 2020 3:23 pm
I am attaching an attempted solution to a an intervention model with an abrupt start and permanent effect. The example is found in "Forecasting, Time Series, and Regression, 4th ed.", Bowerman, et al. The example discusses Atlantic Bell Telephone information calls after imposing a charge. Calls decreased abruptly with a permanent decline. What I need help with is an intervention model that has an abrupt start and a gradual decay. Can anyone help with this request? I attached a model and a couple pages from the Bowerman text.
"Dum" now added to EViews file. Oversight on first upload.
t12-4 directory assistance_solution.wf1
(42.26 KiB) Downloaded 1257 times
Atlantic Bell Telephone Example.pdf
(2.33 MiB) Downloaded 1355 times
