Eviews 7 crashes when forecasting from state-space
Novi
Postby Novi » Fri Nov 23, 2012 12:58 pm
Dear eviews experts,
I think I have found a bug (or something similar) in eviews 7 (premise: my version is totally up to date, i downloaded and installed the last patch just now)
I have a long of program where at the end I make forecasts n=2 steps ahead from a state space model.
Each time I run it when the program arrives to the point of the forecasts it inevitably crashes :( do you have any idea of what's happening?
Hope you can help, it is quite urgent...thanks
Re: Eviews 7 crashes when forecasting from state-space
Postby startz » Fri Nov 23, 2012 1:25 pm
You might want to post your workfile and program so the EViews folks can try to reproduce the bug.
Postby EViews Gareth » Fri Nov 23, 2012 3:25 pm
Also, tell us your build date (from Help->About EViews).
Novi
Postby Novi » Sat Nov 24, 2012 1:21 am
Hi! thx for your prompt replies
I have send the files to your support email and as I said before my build is the latest one, 7.2 updated with the November '12 patch.
Hope I will hear from you soon
Novi
Postby Novi » Mon Nov 26, 2012 3:35 am
did u receive my files to the email address support@eviews.com ?
Postby EViews Gareth » Mon Nov 26, 2012 8:48 am
Yes, we're investigating.
Novi
Postby Novi » Mon Nov 26, 2012 10:45 am
thanks! hope 2 hear from u soon!
Postby EViews Glenn » Mon Nov 26, 2012 4:34 pm
The problem is that there is an error in your program that we weren't anticipating and have done a poor job of handling. Your sspace forecast is trying to do a two-period-ahead forecast with a forecast sample of 1 observation. It can't do this and issues an error, which we don't handle very well (unless you consider crashing good error handling--which I don't :oops:). I've put a fix into the code base for this and it should appear in the next update.
The two-period-ahead forecast error problem is one you'll have to fix yourself :)
Novi
Postby Novi » Tue Nov 27, 2012 1:51 am
Dear Glenn
Of course I will handle the error myself :D but still it is good that u could put a fix into the crash itself...
it is difficult to correct errors if eviews gets stuck and I need to reboot every time!
Thank you very much,
Postby EViews Glenn » Mon Dec 03, 2012 3:58 pm
Patch should be posted. Let us know if you have any other problems.
