Edited post.
Sorry, I have to admit the message was not so clear.
The problem occurs whan the changed string contains the string wich is to be changed, for instance when you change "b" into "bc".
With the text :
aaababaa
You get first :
aaabcabaa
then :
aaabccabaa
aaabcccabaa
aaabccccabaa
etc.
and the second b will never be changed.
What happens is that the cursor does not move with the repetition. This is contrary with usage.
With any other editing program you will get :
aaabcabcaa.
I hope this is clearer.
Jean Louis B.
Edit / Change
Edit / Change
Re: Edit / Change
I'm not sure I understand this. How are you doing the change?
Re: Edit / Change
With the text :
aaababaa
You get first :
aaabcabaa
then :
aaabccabaa
aaabcccabaa
aaabccccabaa
etc.
aaabcabcaa.
Jean Louis B.
With the text :
aaababaa
You get first :
aaabcabaa
then :
aaabccabaa
aaabcccabaa
aaabccccabaa
etc.
aaabcabcaa.
Jean Louis B.
Re: Edit / Change
Still not clear what it is that you are actually doing. Could you provide a concrete code example?
