Edit / Change
jlbrillet
Edit / Change
Postby jlbrillet » Tue Apr 14, 2009 6:42 am
Edited post.
Sorry, I have to admit the message was not so clear.
The problem occurs whan the changed string contains the string wich is to be changed, for instance when you change "b" into "bc".
With the text :
aaababaa
You get first :
aaabcabaa
then :
aaabccabaa
aaabcccabaa
aaabccccabaa
etc.
and the second b will never be changed.
What happens is that the cursor does not move with the repetition. This is contrary with usage.
With any other editing program you will get :
aaabcabcaa.
I hope this is clearer.
Jean Louis B.
Re: Edit / Change
Postby EViews Gareth » Tue Apr 14, 2009 8:06 am
I'm not sure I understand this. How are you doing the change?
jlbrillet
Re: Edit / Change
Postby jlbrillet » Wed Jan 19, 2011 9:30 am
With the text :
aaababaa
You get first :
aaabcabaa
then :
aaabccabaa
aaabcccabaa
aaabccccabaa
etc.
aaabcabcaa.
Jean Louis B.
Re: Edit / Change
Postby EViews Gareth » Wed Jan 19, 2011 9:56 am
Still not clear what it is that you are actually doing. Could you provide a concrete code example?
