cointegration test problem
I have EViews 7.2 version. I was doing cointegration test for my panel data, when I selected Fisher(combined Johansen) and run the test, a error message says "invalid or duplicate specification or insufficient data for estimations." But If I select the other method which is Kao(Engle-Granger based), the test would be fine, it gave me result to reject the H0.
Thanks for any suggestion
- kao.jpg (84.13 KiB) Viewed 12437 times
Re: cointegration test problem
You should update to EViews 7.2.
sorry, it is 7.2 version.You should update to EViews 7.2.
What's the build date? (You can check from Help->About EViews)
Enterprise Edition -May 4 2011What's the build date? (You can check from Help->About EViews)
Please update to the latest version (Help->EViews Update).
I updated to Aug 24 2012 build, but it still the same, shows the error message.Please update to the latest version (Help->EViews Update).
Could you post your workfile?
SureCould you post your workfile?
- CSI150.WF1
- (188.61 KiB) Downloaded 487 times
You don't have enough time periods to do an 11 variable Fisher cointegration test. Our error message could be a little more descriptive.
i c, i only got 10 years, so i need at least 11 years data do to the fisher test? Thank you very much.You don't have enough time periods to do an 11 variable Fisher cointegration test. Our error message could be a little more descriptive.
You'll need more because of the lags in the VAR.
No, you'll need way more than that.
Thank you very for helpingNo, you'll need way more than that.
Hi, I read your post in Eviews I have same question about panel cointegration. I used fisher ADF unit root test and then I couldn't use pedroni or fisher . I can use just Kao test . so I want to know what did you do after that? you used Kao or what?
Regards,
amirpooya
Regards,
amirpooya
