Hi together, I have some questions about the right modeling.
I have time series data and my regression looks like follows
Y c X1 X2t-1 X3t-1 X4
My variables are integrated in order 0,1 and 2 like follows:
Y, X1, X2, = I(0)
X3 = I(1)
X4 = I(2)
What is now the right approach?
a) Do I take the first difference of variable X3 and second difference of X4 to assume stationarity so that my regression looks like:
Y c X1 X2t-1 d(X3t-1) d(X4,2)
b) or do I simply include an ar(1) term like
Y c X1 X2t-1 X3t-1 X4 ar(1)
c) or do I include both like
Y c X1 X2t-1 d(X3t-1) d(X4,2) ar(1)
My second question would be regarding co-integration. To make my anlaysis more interesting I would like to do co-integration analysis and granger causality.
As far as I am concerned, the Johansen co-integration approach can just be conducted with variables integrated in the same oder (order of 1 or more). But my dependent variable is I(0). Is there a way to do the co-integration test anyway?
I read here http://forums.eviews.com/viewtopic.php? ... ardl#p3390 about an ADRL approach but I do not reall get it.
Thank you very much in advance for your help
Stationarity and Co-Integration
Re: Stationarity and Co-Integration
Can no one help me ? :(
I will post my workfile to illustrate my problem.
All variables are I(0) except of
CH_UKREAL, RS_UKREAL & GBP_RUB which are I(1)
and
GBP_CNY & GBP_HKD which are I(2)
Art is always my dependet variable and crisis is a dummy variable
I want to check the influence of the different countries in individual and aggregate form on art.
So for instance, my initial OLS regression (=CHINALAG) for China on art was
ART c GBP_CNY CH_UKREAL(-1) CRISIS
To account for stationarity I modified it to (=CHINALAGDIFF)
ART c D(GBP_CNY,2) D(CH_UKREAL(-1)) CRISIS
Is that the right apporach????
As you can see from the regression outputs, the significances disappeared in the second model and the adjusted R^2 is smaller. In addition DW statistic does look worse , so I doubt that my approach was right.
I really would appreciate you help.
• Have I done the modeling right?
• Should I add AR(1) instead (or in addition) to the differences?
• Is there a way to apply cointegration on art even though the variables are integrated in different order?
Thanks a lot in advance. I hope someone is willing to help me here.
and
- master_regression.wf1
- (81.32 KiB) Downloaded 555 times
still wondering...
I hope someone responds to your question on the differencing of terms for your model, because I'm having the same problem myself! My y variable is I(0) but x variables a variant of I(1) and I(2) terms.
With regard to Johansen, why would you want to include y in the test since it is I(0) and therefore stationary? I thought what would be interesting is the long run relationship between your I(1) and I(2) variables which are non-stationary, in which case you can do a Johansen by converting your I(2) variable into I(1) by using genr dx = d(x,1) and the running dx and the other I(1) in Johansen.
Hope someone can confirm this and the model specification question please, I'm a beginner in econometrics and would appreciate help from more advanced folks. Thanks!
Hi Siewwen,
thanks for your reply.
Regarding the model, I think the right approach is to include all variables with the neccessary differences as soon as it is economically considereable, so this one
should be the right one.
To include as ar(1) model is just useful if you have autocorrelation. In reference to what startz is saying (http://forums.eviews.com/viewtopic.php?f=4&t=1289), autocorrelation on individual level can be disregarded, just the final regression must no be autocorrelated. If that is the case, one might want to add an ar(1) term.
I am still wondering about the purpose of the Cointegrationt test. If you are runing an OLS with differenced variables yoz are checking on co-movement. If you do the Co-integration test, on I(1) level variables, you check on co-integration. Where exactley is the difference?
I am also wondering how to interprete the Johansen Cointegrationr results.
What is the conclusion, if I can reject the H0 in all rows like indicated in the attached file.
If I can reject both, that there is no cointegration, and that there is at most one cointegration vector (two variables). Is it inconclusive? Or can I conclude that there are one or more cointegration vectors, even though I have only 2 variables? I am abit puzzled here
- cointegration.png (24.32 KiB) Viewed 9073 times
To state the question simple, is it possible for two variables to have two cointegraded relations?
Or can I derive no conclusions from the test results at hand?
