Hello Again!
I have two questions please
1) Suppose I run a panel, but neglect to apply and fixed/random effects across both time and cross section. What am I doing exactly here then? Am i just runing a giant/pooled OLS?
2) After estimating my panel, I was checking for outliers by examining the view, residual table. Is there an equivalent eviews equivalent function to STATA's lvr2plot command?
How do I then remove these observations? Say observation 200 for 1992. Is there an easier way then typing it in meticulously framing it? ( say in 1-10 if i want to remove observation 4 I usually type 1 3 5 10). My data is 800 observations, over 4 years
so it is structured
obs1 91
92
93
94
etc.
Thank you very much!!
about the panel and outliers
Re: about the panel and outliers
1) Yep. As the following quick program proves:
2) I'm not sure what LVR2PLOT does, but EViews doesn't have a way of examining outliers (yet).
An easy way of removing large outliers is to say something like:
smpl if @abs(resid)>20
create a 1990 2010 20
series id = @obsnum
series y=nrnd
series x=nrnd
equation panel.ls y c x
pagestruct id
equation giant.ls y c x
show panel
show giant
cocoabutter
Ah ok, thank you.
So that is directly comparable with a pooled OLS, yes?
Also,do you mean sample if abs(resid)<20?
He means "smpl"Ah ok, thank you.
smpl is the EViews command to set the sample.
sample is the EViews command to set the smpl.
Hey, sometimes life is counterintuitive!
cocoabutter
heh i was talking about the sign
Yeah, you're right about the sign.heh i was talking about the sign
