about the panel and outliers
cocoabutter
Postby cocoabutter » Tue Apr 07, 2009 5:03 pm
Hello Again!
I have two questions please
1) Suppose I run a panel, but neglect to apply and fixed/random effects across both time and cross section. What am I doing exactly here then? Am i just runing a giant/pooled OLS?
2) After estimating my panel, I was checking for outliers by examining the view, residual table. Is there an equivalent eviews equivalent function to STATA's lvr2plot command?
How do I then remove these observations? Say observation 200 for 1992. Is there an easier way then typing it in meticulously framing it? ( say in 1-10 if i want to remove observation 4 I usually type 1 3 5 10). My data is 800 observations, over 4 years
so it is structured
obs1 91
92
93
94
etc.
Thank you very much!!
Re: about the panel and outliers
Postby EViews Gareth » Tue Apr 07, 2009 7:13 pm
1) Yep. As the following quick program proves:
create a 1990 2010 20 series id = @obsnum series y=nrnd series x=nrnd equation panel.ls y c x pagestruct id equation giant.ls y c x show panel show giant
2) I'm not sure what LVR2PLOT does, but EViews doesn't have a way of examining outliers (yet).
An easy way of removing large outliers is to say something like:
smpl if @abs(resid)>20
cocoabutter
Postby cocoabutter » Wed Apr 08, 2009 7:32 am
Ah ok, thank you.
So that is directly comparable with a pooled OLS, yes?
Also,do you mean sample if abs(resid)<20?
Postby startz » Wed Apr 08, 2009 7:50 am
Ah ok, thank you.
He means "smpl"
smpl is the EViews command to set the sample.
sample is the EViews command to set the smpl.
Hey, sometimes life is counterintuitive!
cocoabutter
Postby cocoabutter » Wed Apr 08, 2009 7:59 am
heh i was talking about the sign
Postby startz » Wed Apr 08, 2009 8:04 am
Yeah, you're right about the sign.
