I am trying to use GARCH(1,1) to estimate the parameters for the long-term volatility.
I am following John Hull's method of calculating the long-term volatility.
The long-term volatility is (Coefficient of C) / [1 - (Coefficient for RESID(-1)^2) - (Coefficient for GARCH(-1)]
subsituting w for the Coefficient of C
a for the Coefficient for RESID(-1)^2
b for the Coefficient for GARCH(-1)
You get, Long-Term Variance = w / (1-a-b).
I imported the return data into eviews where return(t) = price(t) / price(t-1) and ran the ARCH method.
Under mean equation, i put, "return c" and leaving all else as default, I pressed OK.
Running this under different time intervals, w, a, and b are sometimes negative.
On some instances, the sum of a and b are greater than 1, which causes the long-term volatility to become "mean fleeting".
How do I adjust the estimation parameters so that the following two constraints are always met?
Constraint 1: a > 0, b > 0, w > 0
Constraint 2: a + b < 1
If anyone sees me doing anything wrong here, please advise. Thanks in advance.
GARCH constraints not met?
Re: GARCH constraints not met?
EViews doesn't let you impose constraints on coefficients. However, if you do a forum search you'll see there are a couple of tricks you might be able to use.
Is it possible to specify explicit coefficients for the GARCH terms?EViews doesn't let you impose constraints on coefficients. However, if you do a forum search you'll see there are a couple of tricks you might be able to use.
Ah, good point, it is not, and I apologise for not reading the original post thoroughly enough!
