Shell Md "C:\Temp\Prognosutvärdering"Code: Select all
%Path="C:\Temp\Prognosutvärdering"
Shell Md %PathCode: Select all
Shell Md C:\Temp\PrognosutvärderingCode: Select all
Shell Md {%Path}Snippet 2: Doesn't work, creates a directory with the truncated name C:\Temp\Prognosutv.
Snippet 3: Causes an EViews error. (This syntax works just fine if done from a command prompt.)
Snippet 4: Works.
(I am using the April 27 2012 build of EViews 7.2 Enterprise Edition.)
