Shell command
paues
Shell command
Postby paues » Wed May 09, 2012 2:24 am
There seems to be some problems with the Shell command.
Shell Md "C:\Temp\Prognosutvärdering"
%Path="C:\Temp\Prognosutvärdering" Shell Md %Path
Shell Md C:\Temp\Prognosutvärdering
%Path="C:\Temp\Prognosutvärdering" Shell Md {%Path}
Snippet 1: Works (i.e. creates the directory C:\Temp\Prognosutvärdering).
Snippet 2: Doesn't work, creates a directory with the truncated name C:\Temp\Prognosutv.
Snippet 3: Causes an EViews error. (This syntax works just fine if done from a command prompt.)
Snippet 4: Works.
(I am using the April 27 2012 build of EViews 7.2 Enterprise Edition.)
Re: Shell command
Postby EViews Jason » Wed May 09, 2012 1:27 pm
We will have it fixed in the next patch
Re: Shell command
Postby EViews Gareth » Thu May 10, 2012 9:58 am
Which is now up.
